While-loop and simulation loop.
I am working on the control of the popular 4-tank lab process.
I have developed a Kalman Gain for implementing a Kalman Filter
estimator. After I put the VI of the Kalman Gain (it has a while loop) into the main VI
to implement the estimator, the program was not working? Please, I need urgent
advises on what to do...it is a project work with very limited time left.
Message 1 of 9
(5,703 Views)
It would help if you post your code and describe what you mean by "not working".  What exactly is the program not doing?
- tbob
Inventor of the WORM Global
Message 2 of 9
(5,686 Views)
Which version of LabVIEW are you working with?
Did you use LabVIEW Control Design and Simulation Module to design your Kalman Filter?
Andy Chang
Message 3 of 9
(5,673 Views)
I have implemented the K Filter in a formula node, even the
Kalman Gains were implemented in formula node. It is about
estimating the levels and outflow from lower two tanks of a 4
tank process, so I have to separate K.filters.
The 2 Kalman gains are working well in a while-loop but when connected
on the main program VI to the Kalman estimator, it doesnt work rather
shows an error message.
The name of the program VI is: Main_Kalman implementation.vi
And the expected results are 2 estimated levels and 2 estimated outflows.
Message 4 of 9
(5,669 Views)
Hey Vicky,
Could you also attach your VIs as well?
Andy Chang
Message 5 of 9
(5,659 Views)
attached is a folder containing the main VI and
its dependencies.
 The main VI is: Main_kalman implementation.
thanks.
Message 6 of 9
(5,653 Views)
Hello Vicky,
I'm assuming you are having issue with your implmentation of Kalman Filter using Formula Node, is that correct?
Is there a reason why you are not using Kalman Filter VI like you were doing earlier in your program?
Andy Chang
Message 7 of 9
(5,618 Views)
And now my Kalman filter estimator is working very
smart...thanks guys for suggestions and advices!!!!
Message 8 of 9
(5,607 Views)
Dear Vicky,
May you send me your program?
my email: immirandatracy@gmail.com
Thanks so much.
Message 9 of 9
(5,155 Views)
