While loop Control Problem / button problem
According to my program, when user hits the toggle button the program starts to read from serial port. how it does this, button is wired to case structure and inside the case structure I defined while loop to maintain reading operation.. but the problem is when I hit the read toggle button to stop the program, it does not work since it cannot stop the while loop, still I have no solution, I will add the VI that I try some solutions on it..
"You live in a graphical world. Why not program in one?"
(2,798 Views)
Your read button is outside the while loop and hence it will only be read once. If you need it to be read every iteration of the while loop, you need to place the read control inside the while loop.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,793 Views)
