Which is preferred: Labview for Everyone or Learning with Labview?
I'm a beginner Labview user, though I have gone through the basics throught the 6 hour tutorial posted on the NI website and I'm currently going through the massive list of examples included in Labview. I've heard both Labview for Everyone and Learning with Labview as recommended texts. I prefer to just purchase one, unless I really should get them both eventually. Thoughts and opinions for comparing the two?
(4,872 Views)
I have not seen Learning with LabVIEW so I won't comment on that. I learned (started) LabVIEW using LabVIEW for everyone.
This is very nice book to start with. It has good explanation and examples and tutorials at end of every chapter.
Best Of Luck Smiley Wink
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(4,863 Views)
Thanks!
I haven't heard much about Learning with Labview so I'm hoping to get more opinions on that.
(4,833 Views)
Accepted by topic author calico_cat
Both books are very good.  If your just starting out, go to Amazon, buy a used copy of Learning with LabView 8 or 9.  I got mine for $18 shipped.  You can download all the vi's.  Then also buy LabView for everyone $61.  LabView for everyone covers almost everything about LabView and take you to more advanced stuff, but Learning with LabView was better for the basic stuff.
Jerry
(4,818 Views)
Where did you get that tutorial man?
(4,799 Views)
Raptor 50--Thanks! I will do that then.
(4,794 Views)
clepton7--The tutorial can be found here: http://zone.ni.com/devzone/cda/tut/p/id/5241 . I also found the Labview manual to be helpful, as it is in a tutorial format.
(4,791 Views)
