Which changes in MAX are necessary?
I used DAQ-Assistant for configure pressure sensors in LABview. If I connect an indicator panel beside the DAQ-Assistant to show the direct measurements I get the correct signals.
If I integrate some sensors into the block diagram to control the signal I get for sensor 1 the wrong voltage for sensor 2 and 0.
Should I do some changes in MAX?
(2,750 Views)
Hi ,
Can you be clear on your question. Also Upload ur code .
Rgds,
Venky
(2,742 Views)
Good morning Mr. Weiß,
I have to agree with Venky. We would like to help you with you problem but just with that what you discribe in your post I am not able to catch the problem.
It would be really helpful if you post your code or a small example here.
Regards
Johannes Gräper
Applications Engineering
NI Germany
(2,717 Views)
