Which alternative Programing Language do you suggest ?
Well said Paul..
Pnt wrote:
RayR wrote:
For instance, I need to write embedded software in VxWorks.
Which programming language do you use ?
C...  Good old C 😉 on Unix.   The portion I work on does not have Real-Time restrictions, and mostly touches device drivers.
Message 11 of 27
(1,382 Views)
Visual C++ has a freeware edition, Visual Studio Express. (i didn't knew that)
Maybe i will give it a try.
Thanks to all.
Message 12 of 27
(1,344 Views)
Just curious, why do you ask such questions?  Are you planning to learn more languages? If so, C++ (Visual Studio Express) is probably a good idea.  Knowledge is always good.. 😉
Message 13 of 27
(1,328 Views)
Yes. Even if i don't have much free time, Labview can not fulfill all the needs, and sooner or later i think i will need it.
Message 14 of 27
(1,315 Views)
You should also consider some scripting languages as well as XML.
XML used with Labview can be quite interesting 😉
Message 15 of 27
(1,289 Views)
I'm a big fan of Python.  I've done a fair bit of work getting the two to talk to one another.
I also like using XML in LabVIEW (which JoeLabVIEW mentioned) but it's not really a programming language, as much as it is a data language.
Message 16 of 27
(1,264 Views)
Well said Jim..  Actually, I agree that XML is not really a programming language, but it is good to know nonetheless.. 😉
Message 17 of 27
(1,256 Views)
Python is only 10 Mbytes and it is freeware ?!
Am i missing something ?
Message 18 of 27
(1,217 Views)
what do you mean?
Message 19 of 27
(1,199 Views)
Did i understood correctly ?
10 MBytes seems too small (to me) for a programming language (i downloaded it, from Jim's link), and completely free !
Is this Python ?
Message 20 of 27
(1,194 Views)
