Which DLL's might be corrupted if I can't load ActiveX Ctrls ?
Cannot load CWGraph3d ctrl. Same error with Labview 6.1 & 7. I've repaired, uninstalled, reinstalled and still have same error. If it's a DLL causing this,which one? So I can manually replace it.
(2,603 Views)
The following link is to a knowledge base on NI's website and I believe it directly addresses your issue.
http://digital.ni.com/public.nsf/websearch/FCAAAE31A7A6927386256B640081E212?OpenDocument
(2,603 Views)
Repairing Labview, didn't work. It is now working, by doing the following. Uninstall EVERYTHING from National Instruments, manually delete all directories and files remaining on your C: drive (related to NI softwares), reboot once everything is deleted and reinstall Labview.
(2,603 Views)
