Which DAQmx Version is sutiable for Labview 8.2.1
Hai Guys,
              I am Thiyagu. I have one Doubt in DAQmx. If One year before my senior create One VI. The VI Labview Version 8.2.1. Lastweek running VI Harddisk was crased. I have only source code. I pasted that source code in another PC. I opened that source code It shows DAQmx Write file.VI was Missing. So  i searced Daq file and I find it. So i Pasted that Vi in Source code It shows Labview 11 error. Currnt labview Version is 8.6 and DAQ version 8.8. So kindly tell me How to slove this issue and Which DAQmx Version is suitable for 8.2.1
Please do the needfull.
Thiyagarajan.S
WABCO Vehicle Control System
(3,687 Views)
Any DAQmx should work, I use the latest with LV7.1. You can download it from ni.com or use the CDs supplied with your hardware.
The mistake you made was to copy the missing VIs. You need to run the DAQmx installer instead (after installing LV, so it can detect which LV versions to support).
Felix
(3,679 Views)
DAQmx 8.8 supports LabVIEW 8.2.1 and LabVIEW 8.6 as you can see in the readme file at the download page. Any of the newer versions are compatible.
Error 11 just does not sound right and if you had to paste a function into your VI, that sounds like you did not install DAQmx correctly. You must install the driver after you install LabVIEW.
(3,678 Views)
Hi Dennis,
Thanks for your reply. I have Labview 7.1 software and Driver Cds. This Driver Cds Suitable or not for labview 8.2.1.
Please do the need fiull.
Thiyagarajan.S
(3,647 Views)
I'm a little confused here. Which version of LabVIEW are you talking about? 7, 8.2.1, or 8.6? You say your current version is 8.6, but you have the CDs for 7. Where are your CDs for 8.6? The CDs should have included Device Drivers on other CDs. DAQmx would have been on those discs.
Message Edited by smercurio_fc on 10-03-2009 09:55 AM
(3,632 Views)
Like Felix says, you need to install DAQmx rather than copying the files to your system. Search for "DAQmx" on ni/com/downloads. Version 8.8 should work fine with LabVIEW 8.2.1.
(3,603 Views)
