Which C++ type corresponds to LV string in .NET invoke node
I need to use external C++ class library which usest _bstr_t string as file name type. I'm writing a .NET wrapper with managed C++ for the class so that I can access the class from Labview.
Now I have a problem. I'd like to pass string (filename) from labview to a method using the .NET invoke node.  I don't know which C++ string type corresponds to labview string type in the Labview .NET invoke nodes.  At least the following doesn't work.
#include <string>
using namespace std;
    bool Classname::FileOpen(string* eegfile)
        _bstr_t bf=eegfile->c_str();
nor the following
    bool Classname::FileOpen(char* eegfile)
        _bstr_t bstrfile(eegfile);
Message Edited by Tomi M on 11-21-2005 05:48 PM
Tomi Maila
(2,541 Views)
You need to use a .NET string, not a C++ string. For example, you want something like (VS.NET 2003 syntax)
    bool Classname::FileOpen(System::String __gc* eegfile)
        _bstr_t bf((BSTR)Marshal::StringToBSTR(eegfile), false);
Message Edited by Lycangeek on 11-21-2005 03:26 PM
(2,531 Views)
