Where to find a tutorial for clusters and bundling by name?
I have a huge vi. I need data to flow from one multistep loop to another.  I want to make it a subvi for another vi, but there are too many connections for it to be created.
The help error suggests i use some clusters.
I would like to view some basic examples and tutorials of bundling by name, etc.
However, I need to see the values in the cluster and sometimes edit them.
Any suggestions?
Randall
(2,878 Views)
Have you tried the LabVIEW manual, or the tutorial that comes with LabVIEW, or the examples that ship with LabVIEW, or one of the tutorials that exist on community sites?
(2,852 Views)
Thanks for the suggestion.
Ultimately, I purchased Labview for Everyone 3rd ed by Jeff Travis.
One more question though. Can I modifiy a subvi connection after it is created? Such as adding another indicator.
(2,820 Views)
It sounds to me as if you should look into Type Definitions (aka Typedefs) in LabVIEW, starting with the manual or the online help.  When a typedef is passed into and out of a subVI and a new element is added to it, you don't need to make any changes to the subVI connections.
With regard to your question, though: yes, you can modify subVI connector blocks after they are initially created, but it becomes very painful if you have a lot of instances of the subVI, because you have to update a lot of wiring.
Good luck,
John
(2,813 Views)
