03-08-2006 07:24 AM
03-08-2006 07:58 AM
03-08-2006 08:12 AM
Yes Thomas, seems this property is missing in LabVIEW 8.0
But, I found that if this porperty node is included in a VI built on LabVIEW 7.1, and when this VI is opened in LabVIEW 8.0, it works just fine ![]()
Also i could not find any analogous property node which does this FP origin get/set on LabVIEW 8.0
Maybe it got 'lost in transition' ![]()
ciao
Dev
03-08-2006 08:26 AM
tst:
You're right - I found it:
Property Node VI > Panel > Panes[ ] > Origin.
Thanks for your helpful input.
Thomas
03-08-2006 08:27 AM - edited 03-08-2006 08:27 AM
Tst is correct. It looks like you can get it from the Pane property like this
David
Message Edited by David Crawford on 03-08-2006 08:27 AM
03-08-2006 08:33 AM - edited 03-08-2006 08:33 AM
Message Edited by JamesC on 03-08-2006 02:34 PM
03-08-2006 08:37 AM
Found it!
thanks tst!
may the 5 stars be with you
