Where is the Lockin Demo user manual?
Dear all;
I have downloaded the three VIs of Lock-in start-up kit
http://http://www.ni.com/white-paper/5613/en/
But I have problem of the input cluster of Reference Input of LockinDemodulatorSettings.vi
I don't know the data type of rolloff and type of these inputs.
(3,264 Views)
The Reference Info according to the description is this:
A cluster populated by the LockInPLL.vi.  The cluster contains information necessary to generate mixer and low-pass filter parameters.
What it actually is, is a cluster needing a frequency, phase, order, Updated (whatever that means) a block size, and a "FS" which I'm guessing is the sampling frequency.
Attached is a version that allows you to see the front panel controls so you can see what the controls and type are.  All I did was delete the decoration, saved in 2011.
(3,246 Views)
I have downloaded the file before, and then those pages are found.
Is it means that the corresponding digital display is value for setting the vi?
(3,240 Views)
Your English hurts my head on a Friday.
Those pictures are of enums of the Rolloff and Type.  There is no need to worry about the value behind the setting, just that the right setting is selected.
(3,232 Views)
My mother tongue is not english, so I feel sorry that my english hurt your head.
(3,224 Views)
