Where is subvi nisync?
Good Morning,
I am using Labview 8.6 on a PXI-1045 chassis, a PXI-6653 timing module and a PXI-6552 HSDIO.
I want to use the CLOCK OUT from the 6553, but I cannot find the PXI-6553 NISYNC subvi's.
Where are the  NISYNC subvi's?
I have done a search for NI SYNC on the functions pallete and they are not there.
Roger
Message 1 of 11
(3,915 Views)
Message 2 of 11
(3,903 Views)
Christian,
Thanks for the reply. I installed NI-SYNC 3.0. This is the CD that came with the purchase of the chassis and PXI-6653 module.
After installation, I still cannot find the library of NI-SYNC sub-vi's in the pallete menu.
After NI-SYNC installation, should the library of NI-SYNC sub-vi's be available from the function pallete menu? Because I cannot see the library of NI-SYNC sub-vi's. Where should the NI-SYNC library of sub-vi's be located at. I can see the PXI-6653 module from MAX and I can perform a RESET from MAX, but I cannot find the library of sub-vi's from Labview function pallete menu.
Roger
Message 3 of 11
(3,869 Views)
You should find them in the functions palette under the instrument drivers.
Christian
Message 4 of 11
(3,863 Views)
I checked in the functions pallete menu and the NI-SYNC subvi's are not there. I looked for the NI-SYNC device drivers and they are not installed.
By loading the NI-SYNC from the CD, should that have installed the NI-SYNC device drivers? I already loaded the NI-SYNC from the CD but the NI-SYNC device drivers are not installed.
If I already installed NI-SYNC from the CD, why are the NI-SYNC device drivers not installed and what can I do to install the NI-SYNC device drivers?
Roger
Message 5 of 11
(3,854 Views)
Do you see NI-Sync under Software in MAX?
If so, please post a screenshot of your Instrument Drivers Palette here.
Christian
Message 6 of 11
(3,848 Views)
Yes, I do see NI-SYNC under software in MAX.
In MAX under software, it says
Software - "NI-SYNC 3.0"
Version "3.0.0"
Description - "NI-Sync Device Driver"
Path - "C:\Program Files\IVI Foundation\VISA\WinNT\niSync"
I still don't know why the NI-SYNC subvi's are not in the pallete menu.
Roger
Message 7 of 11
(3,839 Views)
If you don't have the palette there:
then please re-install NI-Sync from the link I posted before.
Christian
Message 8 of 11
(3,835 Views)
Have you closed and restarted LabVIEW since installing the files?
Message 9 of 11
(3,834 Views)
Accepted by topic author R_Rod
I do not have the NI-SYNC in the Labview function pallete like you show.
I have already done a computer shutdown and restarted the computer after NI-SYNC installation, and still there is no NI-SYNC subvi's in the pallete menu.
I will try to un-install NI-SYNC and re-install NI-SYNC from the link you provided.
Roger
Message 10 of 11
(3,822 Views)
