Where is documentation on Front Panel Objects?
This might be silly question, but is there help on Front Panel objects? For example, on the Front Panel, I selected
Modern -> List, Table & Tree -> Listbox.
Now I typed the letters A, B, C in the list box, and right-clicked on the Listbox node on the Block Diagram, and selected Indicator. Sure enough, it showed the list again.
I noticed that the wire was a bold blue line. I then wired this to a For Loop with indexing enabled, and inside the For Loop I created an indicator again, and this time, I ran
the VI and inside the For Loop on the indicator I saw a number, which was the index of the last element selected on the Listbox.
Well, if you are wondering where I'm going with this, here is my question: How would one find out (where is the documenation) that tells a user the bold blue line out of a Listbox
carries information about the entries in the Listbox, as well as the index of any item selected? I mean there are many other Front Panel objects that don't have any help documentation.
How is a person to learn about Front Panel objects? On the Block diagram, I can mouse over, hit Ctrl H and click on detailed help, but can't do anything about Front Panel objects.
Any websites that can help with this?
(2,647 Views)
Accepted by topic author murchak
Right in the LabVIEW Help file
"Should be" isn't "Is" -Jay
(2,644 Views)
Thank you Jeff!
I suppose I got so focused on working with Block diagrams and doing Ctrl H and clicking on detailed help for specific functions, that I forgot about the actual big help file:)
I feel silly. But thanks for pointing me to the right place!
(2,627 Views)
