Where do I get Multi-XY ??
I'm currently desiging a VI that requires plotting a couple sets of data on one graph. The context help showed that Multi-XY will do the job but indicated that its not available in base package. I'm currently using version 6.0.2. Do my version of LabVIEW has the multi-xy?? If not, where can I get it??
(3,006 Views)
If you can run the following example and see two plots on the XY graph, you have the multiplot XY graph.
If you cannot, you probably need to invest in the Full Development System or the Professional Development system.
There are three "Levels" of LabVIEW (Base, Full and Professional) and all use the same version number, so knowing you have version 6.0.2 isn't enough information for us to tell you if you have it already.
I do not know how you can check to see what "Level" of LabVIEW you have.
(3,006 Views)
Thanks for your reply.... but I'm actually looking for a sub-vi titled "Plot Multi-XY". Does anyone have any ideas about this??
(3,006 Views)
The VI that you mention is part of the Picture plots palette and does not come with the LabVIEW base package and the only way to get it is to spend the money for an upgrade. However, the normal XY Graph in every version of LabVIEW has the capability of multiple plots. Is there a specific reason that you want the Picture Plot version?
(3,006 Views)
