Where can I find the 3D Bar Plot Helper in LabVIEW 2014?
Hello everyone!
Sorry if this question is trivial. I know it is supposed to be quite simple. Nevertheless I do not manage to solve the issue.
I need to generate a 3D bar plot.  For this I found the attached  example VI: 3D Bar Chart With Custom Labels 2013.vi.  I tested this VI in LabVIEW 2013 and worked perfectly.  Nevertheless I must work with LabVIEW 2014 (German edition, SP1, f3). When I open this VI with the 2014 version, I get a broken VI.
I realize that in my LabVIEW 2014 I can not find the 3D Bar Plot Helper.vi where I used to find it in the 2013 version (please see the attachen image). Besides the broken VI seems not to recognize the Custom 3D Bar Chart indicator.
I appreciate any help you can provide to me !!!
Sincerely,
Diego
(3,190 Views)
Accepted by topic author Diego_B
Hello every one!
I just found  the cause of this behaviour. The 3D Bar Plot Helper is not available in the Base Development System.  It was possible to see it in the 2013, because this was an evaluation version where the VI was available!.
Thanks anyway !!!
Diego
(3,128 Views)
