Where are the VI's
There is an example of loading the control values from a front panel and also saving the front panel control values shown after I did a search on "Remembering Control Values".
The 2nd solution of this example shows the use of two VI's called "Load VI Control Values" and "Save VI Control Values".
I cannot find these VI's in LabVIEW 7.1. Do they still exist?
(2,531 Views)
I dont think they exist anymore.
You can use the 'Invoke Node Method -> VI -> Get All Control Values' and the Configuration File vi's to create your own functionality or you download the 'OpenG Variant Configuration File vi's' from OpenG.org to get the same functionality.
Hope this helps.
(2,507 Views)
