When using data binding in shared variable the properties does not update?
LabVIEW 2012 with DSC.
On computer A I have a.lvlib with a boolean shared variable with alarms defined.  On computer B I have the same a.lvlib which I set the data binding to point to the shared variable on computer A.  Is it normal that the properties, like the "Ack" are not updated on computer B?
Michel
(3,405 Views)
I believe only values are transferred when doing data binding between bound libraries.  I doubt all the other properties would transfer.
(3,398 Views)
Ok, that's what I though.
Here's an exerpt of what I'm currently trying to do.  I want to create a redundant system (running on Computer B) that would take over from Computer A (critical system) and I'd like computer B to managed the acknowledge alarms instead of putting them back in "Alarms" when it's taking over...
Michel
(3,380 Views)
