When i change the value of a combo box using a property node it displays the value not the item label
I am using a combo box as a select list for text serial commands.  I have items like "engineering", "GUI", and "Scan" for the commands "MDE", "MDN", and MDS respectively which i have input as the corresponding value in the combo box.  so for example the label "engineering" has the value "MDE" in the combo box items list.  when the Vi starts it needs to read the current value MDE, MDN, or MDS and then i want it to display on the front panel the item text corresponding to that command value.
To do this i have tried to read the serial command, ie MDS and then wire that to a "value" property of a property node of the combo-box, but instead of displaying the corresponding item label, "Scan", it displays the value "MDS" on the front panel instead.  i want the front panel to use the label text when choosing and displaying but the block diagram to use the serial commands.  Can this be done with a combo box?  I'm trying to use a combo box so i can keep it all text and avoid having to build a case statement to convert enums or rings from a numerical value to the text command.
The correct text value is wired to the value property and it does exist in the combo-box.  I have unchecked "values match items" and selected to not allow undefined values.
(3,461 Views)
Don't use the value property node.  Use the Text.Text property node.  When creating the property node, select Text, then in the next pop-up box, select Text.
- tbob
Inventor of the WORM Global
(3,453 Views)
