01-31-2012 03:00 AM
Why are unit tests (.lvtest files) added to a support directory when building an application? I cannot find a way to exclude them from the support directory.
01-31-2012 12:18 PM
I'd imagine this is happening to you because they are in the "Dependencies" section of your project file (*.lvproj). Is this correct?
If so, you should add them to your project file somewhere. Then you will be able to prevent them from being installed. In my experience LabVIEW grabs files it thinks are nesecary from the Dependencies list and installs them in a support directory.
02-01-2012 06:17 AM
No, they are not in the Dependencies section, they are in a folder under project.
02-02-2012 02:03 AM
Are you using Unit Test Framework Toolkit?
This files are developed using that toolkit and they automatically are added in the project.
Kind regards,
Ion R.
02-02-2012 03:10 AM
Yes, I'm using Unit Test Framework Toolkit.
But why are .lvtest files added to executable support directory? And how to exclude them?
