What would be the best design pattern for this application?
cireyellamo wrote:
One thing that is part of this project is to create a Power Supply control interface.  Get/Set Voltage/Current, Turn ON/OFF, etc.  I was just going to do a .lvlib for it, though.
Fair enough, tbh I haven't really used libraries much unless I've inherited code.
In our company we've started adding OOP resources to use as like a hardware library, so we've got a class for PSUs, a class for Scopes etc. with the stuff that you always need, and subclasses for each different piece of equipment we use. Then we also have a comms class with subclasses such as TCP/IP and VISA comms.
At first it was difficult to see the benefit as its a lot of extra work to start off with, but now we can just go "I need a Tektronix Scope with VISA comms" and just pull the resources, so half of the code is written for you.
Message 11 of 14
(625 Views)
See, in your case I can see why it would be best to go with OOP.  Work smart, not hard, right!?  For what we do here, I think it best to stick with task-oriented methods.  As awesome as it would be, I don't see the company shelling out that kind of money and time resources for virtualizing the workbench. Would be pretty cool to set up though, thats for sure!
Message 12 of 14
(620 Views)
@cireyellamo wrote:
@billko wrote:
I saw a really neat graphic in my LabVIEW Core 3 stuff that simplifies the decision-making process by turning it into a flowchart based on requirements, but I'm not sure I have permission to reproduce it.
Nice, I'll have to look in to that.  Any idea wich module it is contained in?
I think it was module 14.
Bill
CLD
(Mid-Level minion.)
Message 13 of 14
(609 Views)
Hi crossrulz,
I was suggesting a mod of the producer/consumer pattern rather than the QMH - ie the queue would only be used to send data between the loops rather than control the state machine. The QMH is probably more expandable though I agree - just seems a bit over complicated for the described application.
Smiley Happy
Regards
Paul
CLD running LabVIEW 2012 32 & 64 bit on Windows 7 64 bit OS.
Message 14 of 14
(581 Views)
