What version of LabView do I ned to install in order to utilize the online Core 1 training?
What version of LabVIEW is necessary to access the online Core 1 LabView training? There are many choices for modules, etc. I want the cleanest, simplest installation which will allow me to complete the online LabView Core 1 training course.
(2,401 Views)
Did you look at this?
Base, Full, and Professional are the 3 main types.  Nothing under anything but Base should be needed for the basics in the Core series.  No extra addons should be needed either.
If you have any hardware you want to try communicating with (which is the main reason people use LabVIEW) then you may need drivers or modules for it.  NI-VISA, etc.
(2,373 Views)
Hi, Kyle, I was downloading a trial version of LabView. I didn't notice that there were those three levels of performance available, just a lot of check boxes for what you could install.
Thanks for the input, though. I think I'll try to muddle through with what I have installed and figure it out as I go along. This will be a temporary installation, just for purposes of online training.
(2,348 Views)
