What should be included in the LV 8.5 runtime when using MSXML?
I have a vi using MSXML to create / save XML files in LV 8.5. However, when I create the standalone executable (together with the installer) with the apps builder. The XML portion is not working. Basically the vi converts a table into a xml file and save it. The standalone program can run normal except the portion save/load xml file. The xml file created is empty. I have tried have the client install msxml installer from Microsoft but it doesn't solve the problem. Tried to search in this forum but no results.
(2,922 Views)
Accepted by topic author klaz
The client install of MSXML is what you would need. Are you sure you're installing the same version on the second computer? Do you get any errors from property and/or contructor nodes that would clue you in on what's going on?
(2,908 Views)
Hi Klaz,
Are you displaying your errors in your executable?  If so, are you getting any error codes?
(2,906 Views)
It's the MSXML version issue. I have 4.0 in my computer and my client installed 6.0. Problem fixed! Thanks a lot!
(2,895 Views)
