What's the best Preferred Execution System setting for parallel testing run from TestStand
I configured what vi's I think need to be reentrant, but I am not sure what choice for "Preferred Execution System" is best for the vi's in my TestStand sequence that's going to run in parallel.  Can anyone advise?
Thanks!
(3,138 Views)
Hi mike_22,
This option should not matter unless you have a LabVIEW VI with parallel code blocks.  If this is the case, you can set your VI to Other 1 or Other 2.  Please take a look at this knowledgebase for further explanation.
Cheers,
Kelly R.
(3,115 Views)
