What kind of variant is used for "DB insert data.vi"
How can a variant from "fetch All.vi" be converted into a variant ok for "DB insert data.vi"?
In the attached files I try to doublicate a record in a database. Does anybody know how to make it run?
(2,561 Views)
Umi,
From the 2D array of variants you obtain from the fetch all.vi, you need to extract each value, knowing each variant datatypes and build a cluster of data or variant to use in DB insert data.See VI attached.
Cyril Bouton
Cyril Bouton
Active LabVIEW Developper
(2,561 Views)
