What is the size of a string data type
What is the size of a string data type. Also what is the maximum size upto which a text file can grow?
Thanks in advance
cooldude
(4,143 Views)
Hi cooldude,
the size of a string is given back by the function "String size". Strings are dynamically managed in LabView.
The max filesize is limited by the used filesystem. FAT-based systems are limited to 4GB (or was it 2GB?), other filesystems may allow more...
(4,137 Views)
If what you're looking for is a description of the memory layout of a string, (or any other data type) have a look in the help file section entitled "How LabVIEW Stores Data in Memory"
Rod.
(4,106 Views)
The basic size is Length+4 bytes (size descriptor), although that can change if you use a language which uses more than one byte per character. As Rod said, looking at the documentation is the best option.
___________________
Try to take over the world!
(4,080 Views)
