My intended purpose is to control the Pin2-9(data0-7) logic state at computer parallel port, through these pin,I can control an instrument switch. I use port out.vi , when I write the following binary data 10011110 to parallel port, what is the Pin2-9 logic state? My question is these binary data should go which pin at parallel port when I wirte labview program through Port out.vi? Is it possible that these data go to Pins other than pin2-9?
thank you for help!
Tony
