What is the max number of bits a boolean array can have?
   What is the maximum number of bit that a boolean array can have?
  Kaspar
Kaspar
(2,865 Views)
Your question doesn't make a whole lot of sense. A boolean array is an array of... booleans. It can be any size (limited by application/system memory). A bit is something else entirely.
(2,856 Views)
Follow-up question: What is your concern with the maximum size of an array? Are you running into some limit in your code or something? Is this related to this thread?
(2,848 Views)
There is no real size limit. (except for the natural limits of arrays because the size is a 32bit integer, etc.)
... of course if you ever plan to convert it back to an integer using "boolean array to number", you better stay below 64 bits. 😉
Can you explain what you want to do in a bit more detail?
Message Edited by altenbach on 05-23-2007 02:51 PM
(2,846 Views)
