What is the best way to pass a constant to a cin expecting a pointer to a value?
I have a cin which has a leg that is expecting a pointer to a value. On the diagram, what is the best way to connect a constant widget to this leg of the cin? Connecting it directly crashes labview as it treats the constant as a pointer to memory.
(2,751 Views)
I am not sure that I understand your issue. CIN variables can be Input-Output or Output only. Either way, they are being passed in as a pointer to a value. You can see this very easily by placing down a CIN and wiring a constant integer to it. Next, right-click on the CIN and create the C file. You will see that the parameter list has an int* in it.
If you are still having problems, do you have to create a CIN or can you create a DLL instead? The DLL will give you a few more ways to pass the data than a CIN does with no real performance decrease.
Also, have you read the "Using External Code in LabVIEW" manual? This hsould answer some questions as well.
Randy Hoskin
http://www.ni.com/ask
(2,751 Views)
sorry, newbie confusion, I was getting segmentation faults from 0 address accesses and initially blamed it on passing constants to CINS. It seems to be caused by something else....
(2,751 Views)
