What is the best way to execute code at a specific time?
I have a problem. I need to execute some code at a specific time: subVI A should run at e.g. 2 seconds (after start) and stop at 3.5 seconds and subVI B should execute at 3.5 seconds until 5 s. The user can choose the time points. It could also be that subVI B has to execute before subVI A or at the same time.
Time precission is not important +/- 20 ms is ok.
I have implemented it like that: In a loop (period time approx. 20ms) I query if the timeframe has come and then the subVI will be executed.
See attached picture.
I don't believe that this is an economic way. It will produce high CPU load. How can I do it better?
Greetings Johannes
Using LabVIEW 7.1 and 2009 recently
Message 1 of 17
(3,919 Views)
and how can you insert pictures, so that you see them inside the posting and not as an attachment? 🙂
Greetings Johannes
Message 2 of 17
(3,918 Views)
Like this. Smiley Happy  Use the "Upload or insert an image" option on the Toolbar of the Reply window.
Message Edited by parthabe on 10-13-2009 03:56 AM
- Partha ( CLD until Oct 2027 🙂 )
Message 3 of 17
(3,900 Views)
Use "While Loop" with Case inside, and use Shift register to remember the last time that the Case was executed...
and if you need to run both vi's in parallel use two while loops.
Message 4 of 17
(3,890 Views)
Aah, all right. Smiley Happy
You've uploaded a picture with a red cross?
Message Edited by johanneshoer on 10-13-2009 04:18 AM
Greetings Johannes
Message 5 of 17
(3,885 Views)
@HaD
Something like this?
Johannes
LabVIEW 7.1 (!)
Greetings Johannes
Message 6 of 17
(3,878 Views)
I don't think that this is an optimum solution.
I see a problem. The timer value will wrap from (2^32)-1 to 0, so there might be a problem during comparison.
Even though it is very seldom, I can not accept that.
How can I improve it?
Greetings Johannes
Message 7 of 17
(3,869 Views)
How is this?
Better?
Johannes
LabVIEW 7.1
Greetings Johannes
Message 8 of 17
(3,843 Views)
Yeah, this is definitely a more correct approach. Smiley Happy
P.S.:- PFA the missed-out attachment.
Message 9 of 17
(3,807 Views)
Thanks parthabe,
but doesn't this require considerable processor power? Imagine I needed the timing accureate to a millisecond...
Is there no way similar to event structures?
Greetings Johannes
Message 10 of 17
(3,761 Views)
