What is the best way parsing visa serial read
Hello everyone,
This is my first LabVIEW experience.
I'm working in front of a custom board that has several sensors.
At the board stage, I'm packing all data from the sensors ( digitals inputs & ADC - analog inputs ) to one buffer and send it through UART to the PC (Labview).
Now at the Labview stage, I need to get all packed buffer as HEX string parsing it and show the analog / digital read inputs
The VISA works properly, with a termination character.
Now I wondering :
1) what is the best way to parsing the string buffer - read it on the fly parsing and separating all inputs.
2) How to convert string HEX to waveform?
Thanks in advance.
(3,795 Views)
It helps if you attach your VI with some data saved in it as an example of what you receive.
You say it is "string Hex".  That had different meanings to different people.  I interpret it as a string of human readable characters of 0-9,A-F.  Is that true?
In which case you can use Hex String to Number to convert the characters to values.  You can do it in a loop.  There are lots of people asking for the same thing on the forum.
Since you say it ends in a termination character,  (line feed, carriage return?), I would to a VISA read with more bytes than the longest message you ever expect to receive.   Now you have a complete packet of data, you can parse at once and send the various values out to where they belong.
(3,787 Views)
Thanks for your help.
Yes, it's correct.
I'll search for example
What is the best way to parse the reading buffer ??? If you can direct me to example it will be great.
(3,778 Views)
Accepted by topic author moranfarky
Like this.
There are certainly several other ways to do it.
(3,775 Views)
I really appreciate your help.
Can you please send it as VI and not png because I'm not familiar with all converters and the modules you used for the parsing.
Again, thank you.
(3,720 Views)
Hi moran,
That images is a "snippet": download that image and drag it into your block diagram.
(Read the LabVIEW help for "snippets"!)
(3,690 Views)
Great to know. 👌
Thanks.
(3,683 Views)
