What is the benefit of passing variables to Vi's instead of Refs?
One more thing, if I want to call the coordinator, from either vi, depending on which vi is started first how do I do that?
for instance "That Vi" is called first, somehow the coordinator is executed, then "This VI" is also opened at a later time.
Or, "This VI" is called first, the coordinator is executed, then "That VI" is also opened at a later time.
Is there a way to detect if a vi is already open and open it or not open it (case statement) depending on it's state?
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
Message 31 of 32
(580 Views)
You can also look to see the vi's run state with a property node.
In you case I would probably create a launcher for all three vis that call the run method for each and closes itself
"Should be" isn't "Is" -Jay
Message 32 of 32
(577 Views)
