What is DBL block? Why am I not get an array of numerical outputs?
I am trying to use the Peak Detector. I checked out this post.
In the picture, the Locations output is connected to a block called DBL?
I searched DBL  in my block diagram and this is what I got:
 How do I get his DBL?
(5,088 Views)
Numeric Constant.  You can change the representation to be of type DBL.
(5,069 Views)
It's an indicator of an array of doubles. You put that on your front panel and the block diagram terminal appears.
Three ways to get that:
1- Drop a Numeric indicator on the front panel along with an Array frame. Drag the Numeric into the Array frame.
2- Drop a Numeric indicator on the front panel, then right click on it, then Convert to Array.
3- Right click the output terminal of the subVI and click "Create Indicator"
(5,060 Views)
