What information is stored/pulled from a buffer
Hi I have created a VI which reads and writes data continuously from multiple channels. I have used DAQ mx timing and DAQ mx read with analog, 1D, waveform, N samples, N channels. I know that the sample rate determines how many samples will be taken per second (eg: 1000Hz = 1000 samples per second). I know that the number of samples per channel is the number of samples that will be pulled from a buffer each iteration and determines your buffer size.
Questions below refer to 1000Hz sample rate and 100 samples per channel.
My question is how exactly does the data get pulled and stored from the buffer?
If 100 samples out of 1000 taken in a second are stored in a buffer, is it the first 100 samples that are stored or is it random?
After the 100 samples are stored is the output from the buffer an average of the 100 samples taken or is the output 100 different samples of data and in what order?
Thanks for any help!
(2,828 Views)
Hi cwel,
So you know the basics: "iteration time = samplerate * number of samples"…
Are you sure about this? "Number of samples to read" only determines the "number of sample to read"!
It's like a (size-limited) FIFO.
Surely you read the oldest samples as they are put into the buffer "in order"!
Why should you get an average???
Yes, sure!
and in what order?
Oldest samples first: "size-limited FIFO"!
(2,801 Views)
Hey GerdW,
Thanks for the response!
A size limited FIFO makes a lot of sense. With respect to the previous example of 1000 Hz and 100 samples per channel.
Does that mean if I have 1000 Hz sample rate, in the first second the first 100 samples will be stored in a buffer and the other 900 disregarded. Then the buffer will output those 100 samples in the order that they arrived (FIFO)?
Therefore on average the program will record data every 10 milliseconds (1000Hz/100 samples = 10 )?
(2,769 Views)
Hi cwel,
The first 100 samples will be put into the buffer in just 0.1s! (100 samples / 1kS/s = 0.1s!)
Why should the be disregarded? They are also put into the buffer!
Yes, you read them in the order they arrived…
Wrong in two ways:
- "on average" is wrong, it's "exactly" because of the hardware timing of your DAQ device!
- "10 ms" is wrong, because of 100 samples / 1kHz = 100 samples / 1000 samples/s = 0.1s… (Didn't you learn how to handle units?)
(2,758 Views)
