What has happened to the Matlab node after the upgrade to LabVIEW 7.1.1
I have uppdated my LabView to 7.1.1. My problem is that when I send a string into the Matlab node it doesn't seem to understand that it is a string. I use a command "cd (Workspace)" in the node to set Matlab to work in the right directory. The variable Workspace is sent to the node as a string or a path. The error message I get is that "cd" needs a string to work.
I done the same operation in LabVIEW 7.1 and it worked fine.
So my question is: What happened to the Matlab node after the update and has it been tested by the developers?
(2,564 Views)
Look in the mathematics>>formula nodes.  This is where it is on my LV 7.0.  In older versions it was in the structure node but has moved.  If you ever need to find a function click on the search button on the function palette and type in the function i.e. matlab script then Labview will locate it for you.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,554 Views)
Oops I should have typed Analysis>>Mathematics>>Formula>>MATLAB Script
Paul
Paul Falkenstein
(2,553 Views)
