What happens with EXE2 if EXE1 crashes?
Hi Community,
Yeah, thats a way to generic subject. I am running two EXEs both compiled from LabVIEW. I am wondering what happens with EXE-2 if EXE-1 crashes. Will it continue to run or will it crashes as well. The crash of EXE1 does not cause an entire OS crash, it just shows the crash dialog.
I can speculate as well, please respond only if you know the answer for sure.
thanks!
(3,623 Views)
Are there any dependencies between the applications like TCP connection, ActiveX, drivers, ...?
If not, the second EXE should resume without issue as the RTE should run for each instance separatly. However, i haven't make a test on this, so it is more an assumption.
Norbert
Norbert
Expert: Geometry
(3,617 Views)
No dependencies. But as I said... I can speculate as well.
(3,613 Views)
Accepted by topic author 1984
Each executable runs in it's own application instance - so one of them crashing won't cause the other to crash *unless* it depends on a shared resource or a shared NI component - like for example if your program crashes because they both use shared variables and the shared variable engine crashes, then you'll have a problem.
We often run two or three applications in tandem - the only time we had a problem was when there was a problem with .NET that caused both to crash.
(blog)
(3,595 Views)
