What does this message mean ?ni compactrio driver support for labview 2015 is missing
I get this message ni compactrio driver support for labview 2015 is missing. Is very fustrating. I installed all the cd that came along my rio, i also have something called toolkit installed allready. Its when i start a program downloaded from net mybot ( segway program) i get this message. Has anyone the same problem? solutionfaulti.jpg
Message 1 of 25
(5,380 Views)
Did you install the drivers also?
You need to have the NI-RIO driver installed. You should find it on the DVD's or you can download the driver on the NI site.
Message 2 of 25
(5,353 Views)
Yes, I installed a driver dvd also.
Do you know if a early 2013 version will cause problem when i use 2015? I got 2013 from mydaq 2 years ago.
I got myrio for 2 weeks ago with 2015 version
Message 3 of 25
(5,340 Views)
Please go into NI-MAX and verify that you have installed all the drivers, and what version you have installed.
Message 4 of 25
(5,324 Views)
Hi student,
what did you install?
"something called toolkit" and "some driver dvd" isn't enough information fur us to tell you what's wrong! Please check, what software you did install (MAX -> Software section).
You need to install drivers after you did install a new LabVIEW version. And you need to install drivers for each LabVIEW version you want to use…
Message 5 of 25
(5,321 Views)
If you installed LabVIEW 2015, you need the latest cRIO and DAQmx drivers.  Any driver set from 2013 will not be compatible with LabVIEW 2015.
Message 6 of 25
(5,317 Views)
Hi!
Thanks, I opend max now and took a picture of what drivers that is installed. see attatchment / also a picture of the DVD i installed.
The program i try to open is a segway program from this forum page https://decibel.ni.com/content/docs/DOC-34547 also this https://decibel.ni.com/content/docs/DOC-30571
Message 7 of 25
(5,306 Views)
Did you install the cRIO drivers AFTER installing LabVIEW?  I would try reinstalling the drivers.
Message 8 of 25
(5,297 Views)
yes, I installed the drivers last.
Thanks! I will try that reinstall
Message 9 of 25
(5,288 Views)
Thanks! looks like it helped for the error I had didn show up 🙂
No I got a new one  363013 message attatchment.
I looked it up on NI now and it says
http://zone.ni.com/reference/en-XX/help/373925B-01/myrioreference/myrio_error_codes/
−363013 A timeout occurred during the last I2C read/write operation.
Any suggestion about this?
From the message attatched there where a lot more information than when I looked it up.
Message 10 of 25
(5,277 Views)
