What does error code -2146777998 mean?
Here is the error message.
错误-2146777998发生于 不明位置
该错误代码未定义。没有对该代码的说明,或者连线输入的数值并非对应于错误输入的错误代码。
错误-2147417846发生于 Excel_Get_Range.vi->Excel_Insert_Text.vi->Append Report Text (num).vi->Report_WriteNTCTestTableData.vi->Report_FileSave_TableData.vi->Report Generation-NTCTest.vi->ProductTest_NTCTest.vi->ProductTest.vi->Define Test.vi中的消息筛选器显示应用程序正在使用中。
translate into english,it means:
 this error code is not defined.the message filter display the applicaton is  being used.
(4,779 Views)
Hummm
I try something : you are trying to use Excel via LabVIEW and may be your Excel is already open..Try to close excel and run the VI.
Chris
(4,776 Views)
thanks for your reply,I upload a picture.the excel need to be opened while i am writing data into excel.
(4,765 Views)
Thanks for the picture, It will help.
Do you know where (in which VI) the error occurs ? On your picture I see 2 VI : "New Report.vi" and "Excel Get Worksheet" - and I am not sure that the error message is related to these VI..
To know where the error occurs put a probe on the error cluster between each VI and you will find the first "No OK".
By the way did you have "Dispose Report.vi" at the end of your program ?
Have a good day on the other side of the planet !
Chris
(4,737 Views)
Hi qzxin,
                 Will this help
(4,674 Views)
