What does VISA Find Resource use as source data?
When a Serial Resource (e.g. COM1) is busy with another application, I want to tell the operator this, specifying the COM number in question. It appears the Port Binding (e.g. COM1) is not known until a successful VISA open has exececuted.  Although I could indicate the alias (e.g. ASRL1::INSTR) that is busy, its not very meaningful.  Visaconf.ini has this information. Is it the right place to go for it?
(2,565 Views)
Yes, this file contains the mapping between the VISA names and the System names. It is the section ALIASES you need.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,545 Views)
Thanks for this confirmation.  JohnBoy
(2,521 Views)
