What causes the following "Developer Error" when I try to run the "setup.exe" file of my Installer? And how do I fix it?!
How are you installing LabVIEW? Are you using a disk or a downloaded installer?
Matt W.
(3,280 Views)
I installed LabVIEW 2013 from a disk, then Service Pack 1 from online.  However, the error is generated when I run the "setup.exe" file of my application's installer (which I created, configured and built in my LabVIEW project), not the LabVIEW installer.  I'm not sure if my answer is clear...?
(3,257 Views)
Oh ok, I understand now. Have you tried running the installer on a different target computer to see if the behavior follows? If it seems to me limited to one computer, try running a registry cleaning software such as CCcleaner. Another option would be to download a fresh LabVIEW installer from our website and including that setup.exe in the installer instead of the one from your disk.
Matt W.
(3,216 Views)
