What cannot be stored in a packed project library?
I tried to build a PPL yesterday and got the error "mathscript node cannot be included in a packed project library."
I have searched for a document that lists all the exclusions, but can't find.
# mathscript node
# VI declared in-line
help?
(2,827 Views)
Hello Odd_Modem,
I don't believe the cause of your problem is because LabVIEW has a "list" of things that can't be included into a packed library. If you are using a MathScript node, you might be calling functions that the LabVIEW Run-Time Engine does not support.
Wan L
http://www.ni.com/support
(2,770 Views)
