What are *.cdpg files ?
Hi!
I'm new to LabView and though I understand that *.cdpg files are database files, I am having trouble finding out exactly what *.cdpg are used for.  Also, can these files be deleted without harming the system?
Thanks in advance!
(3,843 Views)
Google Search.........  http://zone.ni.com/devzone/cda/tut/p/id/6579  Voila!
From the text:
Caution: Do not modify, move, or delete a database file while the database is attached. Doing so results in a database corruption. If you modify or delete a database file while the database is detached, you might not be able to reattach the database, and you might lose some or all of the data in the database. If you move or copy a detached database, move or copy all database files.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,840 Views)
