Weird Table Reference Display Bug?
Okay, this one is a bit obscure, and maybe it's just me having all these display problems.
See if you can reproduce this in 8.2.
Create a new vi.  Drop a table control on the front panel.  Go to the block diagram and make a while loop, and drop the table control into the loop.  Then, create a reference to the table, and before dropping it, move the mouse around in the loop.  I'm getting all sorts of black traces (see image).
I have a vi in which more than just tables (numerics, booleans, etc) do this, but I'm having trouble reproducing those.
This is somewhat trivial, but I'd want to know if something I'd written had a bug.
Message Edited by Will.D on 10-18-2006 11:23 AM
(3,420 Views)
I tried what you said but can't reproduce what you are seeing.
David
(3,411 Views)
Will,
This is likely some issue with a video card driver -- what video card are you using?
--Paul Mandeltort
Automotive and Industrial Communications Product Marketing
(3,396 Views)
I apologize for posting this without having tried it on another machine.  My mistake, I should've thought of that first!
I'm not seeing it on other computers.
The card I'm using is just the crappy on-board card: Intel 82845G Graphics Controller, driver version: 6.13.1.3245
(3,390 Views)
Will,
No worries! Do you notice artifacts in other programs (Word, Powerpoint, etc)?  Your best bet may be looking to see if a driver upgrade is available from Intel.
--Paul Mandeltort
(3,384 Views)
