Weird Read/Create File Function Block Error
Dear Folks,
I need to / have to -> / tried to use Open/ Create/Replace File block to open / scan a .txt file that I synchronized through IE6.0 in the directory:
C:\Documents and Settings\TT\Local Settings\Temporary Internet Files
I was given an error:
"You may not select an existing directory"
by Open/Create/Replace File function block. I tried to copy that file to other directories and it works just fine!
Can someone help me out here?
Have a nice long weekend!
TouTiao
(2,727 Views)
Could you please send a screenshot of your input configuration to the Open/Create/Replace File VI? Read the detailed help for the VI before using it. Everything works well on my end. What exact steps should I follow to duplicate your problem? What version of LabVIEW are you using?
Kalin T.
(2,698 Views)
