Website form data
I am a newbie. I need to enter data into a website form and then parse the html data. I have seen some examples, but they don't work on my LabView 2013. Can someone help me enter form data into a website?
(3,797 Views)
YOu can parse data using web services functions. Try to use webservice functions under connectivity--> Web services.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(3,766 Views)
I apologize for not being clear. My question is about sending input data to a website. Once the data is entered into the website,I can parse subsequent html.
(3,747 Views)
Hi Harry,
How exactly do you want to connect to the website that you are trying to add data to?  Here is a previous forum post that gives a couple of different options for making a connection:
http://forums.ni.com/t5/LabVIEW/how-to-use-HTML-form-vi/m-p/2489438
If you are trying to edit content within the HTML, this is a very handy tool that allows you to look between tokens so you can edit text easier:
http://zone.ni.com/devzone/cda/epd/p/id/1736
Hope this helps,
Nick
(3,717 Views)
Nick,
Thank you. The link with this sample vi looks like it will address my need, however the wires are broken when I load them into LV 2013. I have the Internet Toolkit loaded. I am using LabVIEW for Mac. The frst property node has broken wires on the the Address bar, Menu bar and full screen inputs. The Variant to Node vi has a broken wire for the variant input. I am not sure it the problem is LabVIEW for mac, LabVIEW 2013 or a missing toolkit....
(3,708 Views)
Harry,
I am having trouble viewing the image you uploaded.  Could you use a larger image?
Nick
(3,680 Views)
