WebServices labview 2009 -> <Response/>
Hello, i build a web service as http://zone.ni.com/reference/en-XX/help/371361E-01/lvhowto/web_service_ex/ that get the sum of two values. When i call:
http://localhost/mywebservice/add/2/3
the response of XML is: "<Response/>" and not a valid XML with the sum.
Why?
Message 1 of 10
(4,422 Views)
Hello, in atachment my project. When i run this WS in browser i get:
But when i run WS that i get from http://zone.ni.com/devzone/cda/tut/p/id/7350 it works:
I don´t understand...
Any idea?
Message 2 of 10
(4,408 Views)
Anyone?
Message 3 of 10
(4,378 Views)
Hi, all you need to do is connect the controls and the indicators at the connector pane in the original application. The same way you do while calling a subVI.
Hope this helps.
Message 4 of 10
(4,342 Views)
Hello Sreedhar T, thanks for reply but i don´t understand you because a i don´t call a sub VI and my VI is equal as the VI example of NI that works.
Can you take in my project (last post with attachment) and explain this?
Thanks.
Message 5 of 10
(4,334 Views)
Accepted by topic author PedroTeixeira1985
I solved the problem mapping A, B and Z with that says "Important":
Now, Web Service works!
Thanks for last replies and NI support!
Message 6 of 10
(4,322 Views)
Hi, Im glad you understood.
How do you deal with it when you have arrays of such input and output ?
Message 7 of 10
(4,314 Views)
I have the same problem. But I use the Write Response.vi, and get a blank response, as mentioned earlier. I'm surprised, because I have used this approach, I used the Flex + LabVIEW.
Message 8 of 10
(4,281 Views)
Hello Selentium,
I think that you need map the response in the right square. Your example don´t have anithing maps in right...
In my example i had 2 left squares (two numbers) and 1 right square (the sum).
Good luck.
Message 9 of 10
(4,268 Views)
I used the same approach as in the example from NI. And I have already created a similar application, but this time I have returned an empty response. And I can not find a solution to this problem.
Message Edited by Silentium on 02-24-2010 04:12 PM
Message 10 of 10
(4,265 Views)
