WebServer no picture on Firefox
Hello Homeofficers
I am in a very confusing situation with my WebServer.
I have LabView running on two Pc in the same Network, both run the same LV16. I use the Web-Monitor option with an refresh rate of 1/s.
The aim is to see a picture of the FronPanel in my Browser (Firefox) when connected to the local network by going to IP/Port/Vi_Name.
With Pc(1)  this works perfectly. With Pc(2) the webpages can only be accessed via the InternetExplorer, Firefox just shows the heading.
I read that there are compatiblity issues with the new Firefox versions https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LCKSA2&l=de-DE
But the really confusing thing is: It still works with Pc(1)
I have also tested if the firewall has an influence, it is able to block the server, but turning it off makes no difference.
Both Pc(1)&Pc(2) run the same LV version, so I conclude it must have to do with the local settings on Pc(2), but I can't figure out what is the difference. It has nothing to do with the LabView Vi I am running, if I run the same Vi on Pc(1) I can see the Webpage with Firefox, when running it on Pc(2) I can only see it when unsing the InternetExplorer.
Message 1 of 1
(1,773 Views)
