Showing results forĀ
Search instead forĀ
Did you mean:Ā
Web publishing problem
I have created a vi and published it.I can access that vi url  from a system where labview is installed and I can able to do the experiment.But when I try to acces that vi from a system where labview is not installed it shows missing plug in problem .I installed the plug in coresponding to the version but it still shows the same problem.How this can be solved?
(3,788 Views)
You will need to install the LabVIEW runtime engine on that computer. Hopefully, it should work after that; do let us know if it doesn't.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,774 Views)
Thanks for your reply sir
I installed the run time engine corresponding to that version .Still it shows missing plug ins
(3,769 Views)
Have a look at the following KB article:
Missing Plugin Error Loading Remote Front Panel in Mozilla Firefox, Netscape, Internet Explorer, or ...
Adnan Zafar
(3,765 Views)
Sir I already went through this link .I am using mozilla firfox3.5 and IE 7.I can see the installed plug ins in browsers directory.I disabled antivirus and windows firewall.I dont understand why it still shows missing plug ins.The same problem I can see while acessing the following link.
http://59.163.196.230/emg.html(experiment by some other institution)
To do this experiment i installed 2009 runtime engine.But it again ask to install missing plug ins which is similar to my application problem.
(3,759 Views)
Please any one suggest me a solution .Its necessary for my further work.
(3,734 Views)
