Web based sound reading method
Hi Everyone,
                      Is there possible to hear the the sound if the VI in web page (through web publishing tool). I checked it. I can hear the sound in my server PC. But unable to hear my client PCs. is there any other method  . . . .?
(3,537 Views)
If you can hear it on the server pc, it sounds like you're trying to link to a local file.  When the client pc looks for that local file, it doesn't exist.
Is it possible for you to link to a server address instead of a local address?
(3,503 Views)
I couldn't understand the question...Already I am using only server address to communicate the VI in client PC.
For you I am giving explanations for how i did.
Method 1:
# Main VI file is running in server PC.
# I will give my server PC IP address in local client PC. Steps are: operate-->Remote Panel COnnection--> in that dialog box, I enter IP adress--> then VI name
# Then I can control or monitor according to my need.
Method 2:
# Tools-->options-->Web server--> Give enable for remote control
# Tools-->Web publishing tool-->Choose the VI file-->Embedded option-->then according to screen instructions I ll get the html page link.
# If I am post that link in my client PC it will show the fron panel of the VI file. After that I can control.
But in both procedure, I couldn't here the sound in my client PC.
I am looking forward from your answer.
(3,465 Views)
