Web Services bypass Proxy
I have following problem using WebServices in combination with a Proxy Server in my application.
I have a PXI System (RT)  running a WebServer with different Services for configurations of the system, and there is a Host Appllication on a PC wich communicates with this WebServer.
On the Host PC there are two Network Interfaces ( one is connected to the PXI, the other one is connected to the companies Network). In the System there is used a Proxy Server.
I have following problem:
My Host App is not able to reach the WebServer on the PXI System.
I set the Windows Connection Settings to bypass the Proxy. This works fine for browser (IE,Firefox) and I get access to my WebServices but my Host App is still not able to access them.
Thought that LabView is using the Windows Network settings, or are there some "hidden settings" ?
Thanks in advance for any good advices!!!
(3,252 Views)
Hi Christoph,
maybe this is a first step to a solution:
https://forums.ni.com/t5/LabVIEW/http-through-proxy-connection/td-p/995656
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(3,159 Views)
