Ways of Installing Software into PXIe-8840
I would like to limit the way a software is installed into my controller. (deploy through labview and opkg)
is there a way to prevent user from deploying through labview?
TIA
(1,217 Views)
That’s fairly vague. You can disable project access on the RT controller in Max. That prevents any deployment, interactive or as executable, from a project.
But why is that even an issue? Do you let your users run LabVIEW itself and if so how are they supposed to run the software if not by deploying? If you install a compiled RT app through OPK that should not be a problem.
Rolf Kalbermatter  My Blog
(1,151 Views)
Sorry, didnt mean to be vague.
The scenario i am in is, when you deploy program through LabView, control file is not updated. No one would know what version is installed.
with opkg, control file is created. I want to prevent my team from deploying software through LabView so there is no unversioned software in our controller.
(1,114 Views)
i think you cant have OPKG installing software if the executable exists, ie. if the last is opkg install, you wont be able to deploy through LabView unless you do opkg remove first then do LabView deploy.
This might be it.
(1,113 Views)
